(Southworth Products: Portland, ME) -- The performance requirements of lift tables in a production process are far greater than those of stand-alone lifts. To ensure maximum reliability and uptime in these production environments, Southworth has introduced a production-ready package for many of its most popular models.
By incorporating a series of options, upgrades, and heavy-duty features, the production-ready package minimizes unplanned maintenance and costly production interruptions. With regular PM service, the interval before major maintenance and replacement of renewable parts is extended from 50,000 up to 200,000 cycles or more.
Southworth LS, LSH, and DL Series lifts can be furnished with the production-ready package, with literally thousands of configurations to choose from.
Southworth production-ready lifts feature oversized cylinder rods, high-strength alloy shafts and pins, thicker composite bushings for increased strength and durability, regreasable needle bearing cam followers, reinforced roller tracks with wear strips, upper limit switches, and soft connectivity for electrical connections.
Southworth also recommends the production-ready package for dynamic load handling on lifts with conveyor tops, pneumatic ball transfers or turntables, or where the lifts travel under load, such as on AGVs or towed carts. It is also ideal for nonuniform loads that consistently place more weight on one end or side of the platform.
Because the maintenance interval of these lifts is greatly extended, they are also ideal for use in areas with limited access for maintenance.
For more information, contact Jim Norris, president, Norris & Company, 85 Samoset St., Plymouth, MA 02360. Call 508-510-5626 or email jim@norrisco.com.
