(Artec 3D: Santa Clara, CA) -- Global 3D scanning hardware and software leader Artec 3D has unveiled its first target-based laser scanner as part of its plans to expand further into industrial metrology.
While Artec 3D scanners already offer rapid, accurate, precise data capture to users across industries, the company has now introduced a dedicated metrology solution. Accurate down to mere hundredths of a millimeter, Artec Point consistently captures the high-quality data needed for reverse engineering, quality inspection, and other demanding metrology tasks.
“Our scanners have been making inroads in the field of industrial metrology for years,” says Art Yukhin, CEO and president of Artec 3D. “So it only makes sense to launch a solution that caters precisely to these users’ needs. With metrology-grade accuracy, high repeatability, and long-lasting durability, Artec Point offers a purpose-built industrial solution. We are excited to broaden our offering to customers operating in the metrology space.”
Built for industrial metrology
Verified against VDI/VDE 2634 and JJF 1951 standards, Artec Point’s outstanding 0.02 mm accuracy and precision put metrology-grade 3D scanning in the palms of users’ hands. The device captures objects of different size, finish, and intricacy, including dark, shiny surfaces and deep holes, at speeds up to 120 FPS, or 2.8 million measurements per second.
Thanks to its robust metal casing, Artec Point withstands challenging industrial conditions, while its ergonomic grip and lightweight chassis make it easy to maneuver into tight spaces for measuring difficult-to-access areas.
Standing alongside Artec 3D’s existing metrology offering, which ranges from the desktop Micro II to the LiDAR Ray II, Artec Point broadens Artec 3D scanning’s reach into new applications in automotive, aerospace, manufacturing, and heavy industry sectors.
Artec Point: A unique proposition
Artec Point also features full integration with Artec Studio, a powerful yet easy-to-grasp 3D scanning software. This allows the device to be easily paired with other Artec 3D scanners to develop novel solutions to complex tasks.
Artec Studio is also packed with algorithms that streamline data processing, while Artec Point’s intuitive user interface enables operators to achieve repeatable capture results, regardless of skill level.
An essential tool for reverse engineering and quality inspection, Artec Point’s usability and consistency give it a unique value proposition currently missing from the metrology space.
“In a crowded metrology market, where many scanners offer similar levels of accuracy, Artec Point distinguishes itself with an unmatched combination of precision, intuitiveness, and software integration,” says Yukhin. “With the Artec Studio-powered Artec Point, users can easily achieve accurate results every time—making it a standout choice for applications like reverse engineering and quality inspection.”
Artec Point and Spider II: A joint launch
Alongside Artec Point, Artec 3D has introduced another handheld 3D scanner: Artec Spider II. Capable of capturing ultrahigh resolution, highly textured scans of small-to-medium objects with steadfast accuracy, the device is perfect for uses where fine detail is key.
With these launches, the company has further underlined its commitment to 3D scanning excellence, innovation, and addressing the needs of a wide range of industries with a full range of solutions that meet users’ specific application requirements.
Find out more about Artec Spider II here or Artec Point here. Both will be showcased with Artec 3D’s other flagship technologies at IMTS 2024 (Booth 134478).
