(Novelis: Atlanta) -- Aluminum has traditionally been reserved for luxury and high-performance vehicles. However, advancements in material science, recycling capabilities, and design innovation have transformed aluminum into a cost-effective and sustainable choice for all vehicle categories, from compact cars to SUVs and trucks.
Cost-effective lightweighting for mass-market vehicles
Lightweighting with aluminum is both practical and economical. Modern manufacturing techniques such as hot stamping and adhesive bonding enable significant weight reductions without substantial cost increases. For example, incorporating aluminum components like doors and hoods into existing steel platforms can achieve up to a 50% weight reduction at a competitive cost.
Aluminum’s lower density—approximately 67% less than steel—means that less material is required to achieve the same structural integrity. This reduction in material usage can offset the per-unit cost of aluminum compared to steel, leading to overall cost savings. Additionally, lighter vehicles benefit from secondary weight savings. For instance, replacing 400 kg of steel with 240 kg of aluminum results in a primary weight reduction of 160 kg, which can lead to an additional 40 kg to 60 kg reduction in other components such as brakes and suspension systems.1
Advancing the circular economy
Novelis is one of the world’s largest closed-loop aluminum recycling partner, returning carmakers’ production scrap to its facilities to be melted down and reintroduced into the supply chain. This process not only reduces costs but also significantly lowers carbon emissions, aligning with the growing sustainability priorities of carmakers as well as consumers. Recycling aluminum uses approximately 95% less energy than primary aluminum production, resulting in 95% less carbon emissions.2
Beyond production scrap, Novelis is pioneering end-of-life vehicle recycling initiatives. Through innovative scrap sorting and segregation technologies, Novelis can capture specific aluminum alloys from decommissioned vehicles, preserving the value and quality of the metal.
In collaboration with key industry partners, Novelis is driving an end-of-life vehicle circularity platform to optimize material flow, increase access to high-quality recycled aluminum from decommissioned vehicles, and minimize waste to landfill.3
Recognizing that recycling starts with thoughtful design, Novelis also works closely with automakers to develop sustainable solutions such as uni-alloy designs for components like hoods and doors, simplifying recycling processes, and enhancing material recovery.
Customized solutions for diverse automotive needs
Recognizing that each vehicle has unique material requirements, Novelis collaborates with automakers to develop tailored aluminum solutions that meet specific performance, design, and sustainability objectives. Low-carbon alloys offer exceptional versatility and strength, enabling innovation across a wide range of applications, from electric vehicle (EV) platforms to high-performance SUVs. Even smaller vehicles benefit from lightweighting, because reducing weight enhances fuel efficiency and lowers emissions.
For EVs, lightweighting is crucial to offset the significant weight of battery packs. The result is improved range and overall performance.
In commercial vehicles, the advantages of aluminum lightweighting are even more pronounced because it enhances fuel efficiency, increases payload capacity, and helps fleets meet stringent emissions regulations.
Moreover, reducing any vehicle’s weight with aluminum not only improves efficiency but also enables automakers to use smaller engines—or fewer batteries—and lighter suspensions and brake systems, resulting in additional weight and cost savings.
A collaborative approach to innovation
Transitioning to aluminum extends beyond material supply; it necessitates partnership and innovation. Novelis works closely with automakers, providing comprehensive support from early-stage design consultations to advanced R&D testing at its customer solution centers around the world.
1 Alumobility Outlines 8 Reasons Why Aluminum Is the Material of the Future for Automakers
2 “Recycling Aluminum: Energy and Environmental Benefits,” Sustainability—Recycling: Aluminum Association
3 Novelis and thyssenkrupp Materials Services Partner to Drive Circularity
Published as a blog post by Daniel Kern, vice president, Global Automotive Development, Novelis
