(Mitutoyo America Corp.: Aurora, IL) -- Mitutoyo America Corp., a global leader in precision measurement technology, announced the launch of the MiSTAR 575 Shop Floor CNC coordinate measuring machine (CMM). Building on the success of MiSTAR 555, MiSTAR 575 takes shop-floor performance, accuracy, and measuring range to new heights, offering unparalleled capabilities for a wide range of applications.
Designed to measure small to medium-size workpieces, MiSTAR 575 meets Mitutoyo’s high standards for accuracy, repeatability, speed, and environmental resistance. With its expanded measuring range, MiSTAR 575 is optimized for larger parts while maintaining exceptional performance in demanding environments.
Advantages of MiSTAR 575 to MiSTAR 555
Expanded measuring range: Supports a broader range of workpieces, ideal for larger parts and more complex applications.
Exceptional accuracy: Delivers Mitutoyo precision and reliability.
Optimized for larger parts: Perfect for applications requiring higher measurement capabilities.
Coolant/environmental resistance: MiSTAR 575 maintains the same resilience in shop-floor conditions, including coolant exposure.
Best-in-class temperature compensation: Ensures stable and accurate measurements, even with fluctuating temperatures.
Why choose MiSTAR 575?
MiSTAR 575 offers the perfect combination of extended range and high precision, making it an ideal solution for both the manufacturing floor and the quality inspection room. Whether you’re looking to increase throughput or require a CMM with larger measurement capabilities, MiSTAR 575 will help elevate your production process. Whether expanding your capacity or seeking the best in class for your measuring applications, the MiSTAR 575 provides the perfect solution.
For more information about the MiSTAR 575 Shop Floor CNC CMM, call your preferred Mitutoyo distributor or visit the nearest Mitutoyo M³ Solution Center.
