The aforementioned more sophisticated measuring methods require more lengthy, involved measuring procedures, a relatively high-level skill set and considerable expertise. Although necessary for many applications, complex measuring methods on manually operated systems are also more prone to human error.
Unlike more complex measuring methods, fixture gaging is less labor intensive and requires much less training. Gage operators don’t have to be highly trained. In fact, little or no on the job training is needed—which means short lead time to get operators up and running and the product out the door.
The basic procedure for fixture gaging is to load the part, bring the measuring probes into contact with the part and enter the data. Then remove the part, load the next part and repeat the procedure.
