(Dalsa: Billerica, MA) - DALSA Corp., a global leader in machine vision technology, announces the availability of the BOA vision system, a highly integrated smart camera that comprises all of the elements of an industrial machine vision system. Powerful and quick to deploy, the BOA is ideal for automated quality inspection applications and factory automation.
BOA, an all-in-one machine vision solution is smarter, easier to use, and more flexible than previous generations of smart cameras. It is the first smart camera in its class to incorporate multiple processing engines. This enables algorithm optimization via digital signal processing (DSP), application management via CPU, and sensor management via FPGA. It is also the first smart camera that offers truly embedded application software, which is easily set up through a standard web browser. No software to install; no version control problems. BOA delivers greater flexibility for its users via a rugged, easy-to-mount enclosure, built-in factory communications, and a low deployment cost.
