(FARO Technologies: Lake Mary, FL) -- FARO Technologies, Inc. has introduced the FARO Laser Tracker ION, their latest 3-D measurement system.
The FARO Laser Tracker ION is the most advanced, state-of-the-art FARO Laser Tracker ever introduced. It is the most accurate laser tracker available based on the most common types of measurement applications. It also features a longer measurement range, lighter weight, and contains the fastest, most sophisticated distance measuring system: Agile Absolute Distance Meter (aADM).
Specifically, the ION has improved the volumetric accuracy by 27% over the previous model to .002” (.049mm) at 33 feet (10 meters). The measurement diameter range has been extended 36% to 361 feet (110 meters), and the weight has decreased 12% to 39lbs (17.7kg).
