3D Metrology-CMSC
(MIT: Cambridge, MA) -- Before a robot can grab dishes off a shelf to set the table, it must ensure its gripper and arm won’t crash into anything and potentially shatter the fine china. As part of its motion planning process, a robot typically runs “safety check” algorithms that verify its…
In a highly regulated industry like medical technology, manufacturing processes must undergo either process verification or process validation to ensure they’re consistently producing the correct result. The question is, which one should you use?
Verification and validation are two…
Do you ever feel like you’re spending money like crazy on marketing and getting little or nothing in return? If so, you might be tempted to pull the plug on marketing altogether. That would be a big mistake.
An effective marketing strategy can mean the difference between your organization…
It is well known that the speed of light depends on the index of refraction of the medium in which the light is propagating. It is also well known that in a dispersive medium, the speed of an amplitude modulated wavefront depends on the group refractive index, i.e., slightly slower than the…
The Daniel K. Inouye Solar Telescope (DKIST) is strategically constructed on the summit of Haleakala, 10,023 ft above sea level, which is an ideal vantage point for solar observations. Site construction started in 2012 and moved into the integration, testing, and commissioning (IT&C) phase…
Fringe projection techniques offer fast, noncontact measurements of the surface form of manufactured parts. Fringe projection has seen successful implementation in the automotive, aerospace, and medical industries. Recently, advances in fringe projection have reduced the sensitivity of the…
