(AIT: Melbourne, Florida) -- The groom-to-be was showing the wedding ring off to his friends at work the day before the wedding when it slipped from his grasp and fell down an industrial drain. The drain had about a 10-foot vertical drop before it turned sharply horizontal. The groom-to-be had no idea how far the ring had traveled or how it could be retrieved. Some one suggested a borescope could be used to locate the ring. That was when Advanced Inspection Technologies (AIT) received a very panicky phone call.
AIT ( http://aitrents.com/) specializes in the rental of borescopes, fiberscopes, videoscopes and long pipe inspection cameras for a variety of remote visual inspection applications at industrial sites around the world. Borescope rentals are used to examine pipelines, pumps, gearboxes, compressors, boilers, heat exchangers, headers, valves and air conditioning ducts. Borescopes allow engineers to check for pitting, cracking, corrosion, erosion, weld and other defects in industrial systems that cannot be easily accessed. AIT also rents industrial foreign-object search and retrieval tools. These tools are used to remove loose parts and foreign materials from industrial systems.
Although rarely used for such a purpose, they also happen to be the perfect tools to locate and recover wedding rings in drain pipes.
Groom to be
What a great story! You never know how NDT equipment will be used!
