(NIST: Gaithersburg, MD) -- Scientists have long known that time passes faster at higher elevations—a curious aspect of Einstein’s theories of relativity that previously has been measured by comparing clocks on the Earth’s surface and a high-flying rocket. Now, physicists at the National Institute of Standards and Technology (NIST) have measured this effect at a more down-to-earth scale of 33 centimeters, or about 1 foot, demonstrating, for instance, that you age faster when you stand a couple of steps higher on a staircase.
Described in the Sept. 24 issue of Science, the difference is much too small for humans to perceive directly—adding up to approximately 90 billionths of a second over a 79-year lifetime—but may provide practical applications in geophysics and other fields. The NIST researchers also observed another aspect of relativity—that time passes more slowly when you move faster—at speeds comparable to a car travelling about 20 miles per hour, a more comprehensible scale than previous measurements made using jet aircraft.
So will people start
So will people start extolling the ageing benefits of ground floor offices, or compete for a desk in the basement.
NIST Experiment Proves Your Head Is Older Than Your Feet
So logic speaking, if you would encouter a black hole, then would time stand still?
