In statistics, we use a variety of intervals to characterize the results. The most well-known of these are confidence intervals. However, confidence intervals are not always appropriate. Here we’ll take a look at the different types of intervals, their characteristics, and when you should use them.
I’ll cover confidence intervals, prediction intervals, and tolerance intervals. Because tolerance intervals are the least-known, I’ll devote extra time to explaining how they work and when you’d want to use them.
Tolerence Intervals
Is the functionality of calculating tolerance intervals available in Minitab version 15? I was not able to find it with the directions provided in the article. Thanks.
Tolerance intervals in Minitab 16
