The following personal stories concern vehicles produced by the automaker that invented lean and is world-famous for its efficient manufacturing operations:
• My old SUV’s bright headlights don’t work. When I hit the switch for the brights, the headlights turn off completely. This will cost me $400 to fix because it requires replacing an entire steering wheel subassembly.
• My wife’s car needs a filter replaced; it’s routine maintenance. It will cost several hundred dollars because it requires extensive disassembly to get to the filter, which has to be done by going through the glove compartment.
• I once lost the key to my car. It was one of those keys with security features, and it opened the doors and trunk. It cost me nearly $300 to replace the key. (This was four years ago, when the dollar was still worth something.) I was told that if I lost my remaining key, it would cost me $3,000 to get a new key because the car’s computer security hardware would need to be replaced. As you might imagine, this would require extensive disassembly.
Repair time
I don't usually comment on my own article, but I thought I'd let you know that I got the car from the repair shop after 32 days. That was a month ago and it has been running fine since.
Thomas Pyzdek
http://pyzdekinstitute.com
