In today’s coronavirus environment, governments at all levels are under greater fiscal pressure. For instance, Oregon’s governor has told state departments to prepare for a 12-percent reduction in their budgets. Given this environment, perhaps it is time to reexamine an established approach to improving operational performance. That approach is quality management.
From 1992 to 2002, I researched and wrote about quality award-winning governments in the United States.1 With extra time on my hands, I started cleaning out old files. In the process, I found a few of the documents backing up that work.
The documents included information about 32 local governments that were using total quality management (TQM). While reviewing the current websites of these local governments, I discovered that at least seven are using or mentioning quality management. It might seem disappointing that only seven of 32 are using some form of lean management, Six Sigma, continuous improvement, or Baldrige Criteria. However, that several of these local governments have been implementing quality management for 20 years shows there is a sound quality management foundation in local government. This is a foundation that can be built upon.
