![](/sites/default/files/editorial_images/NIST3d1000_0.jpg)
NIST researcher Thomas P. Forbes is working to ensure 3D drug printers work as designed. Credit: R. Eskalis/NIST
Here are just a few potential advantages of 3D drug printing—a new system for manufacturing drugs and treatments onsite at pharmacies, healthcare facilities, and other remote locations: chocolate-flavored pills for children who hate taking medicine; several drugs combined into one daily pill for seniors who have trouble remembering to take their medications; and drugs printed at your local pharmacy with personalized dosages that best suit your health needs.
In 2015, the U.S. Food and Drug Administration approved the first 3D-printed drug, spritam (levetiracetam), for epilepsy. Several other manufacturers and drug companies are developing their own.
But the widespread adoption of 3D drug printing will require stringent quality control measures to ensure that people get the right medication and dosage. Even a tiny mismeasurement of a drug’s ingredient during the printing process could endanger a patient’s health.
In a new research paper, NIST research scientist Thomas P. Forbes assesses various approaches to ensuring that 3D drug printers work as designed. The journal article applies a “quality by design” analysis to evaluate the best procedures and protocols to ensure that 3D printers produce drugs at the correct dosages and with the correct mix of chemicals.
Though various methods exist for remotely printing drugs, Forbes focused on one of the most common: inkjet printers and similar systems that can print personalized medication on demand.
Like inkjet printers in homes, though larger, the printer has nozzles that deposit the drug’s liquified materials, or inks, into tiny wells on a tray or directly into capsules. Through freeze-drying and other processes, the liquid can be turned into a tablet or powder poured into a capsule. It can also be evaporated onto a thin film that dissolves in the mouth.
Forbes’ paper doesn’t make any recommendations. Instead, his research identifies and tests several possible methods and techniques for maintaining quality control in 3D drug printing.
A NIST researcher is analyzing a 3D drug printer that works similarly to an inkjet printer in a home or office. Credit: R. Eskalis/NIST
I spoke with Forbes about his research.
What are some of the advantages of 3D drug printing?
When your doctor writes a prescription, she knows drugs are available in certain dosages, and she’ll choose the dosage she thinks is best for you. Some drugs come in many sizes, while others come in just one.
3D printing enables you to individualize the dosage. You can do it based on the person’s age, health, even their immune system or genetic profile.
You can also personalize the form that the medicine takes. Some patients may prefer a liquid to a capsule, for example. There’s also been research on polypills, which combine multiple pills into a single drug. And some scientists have focused on the benefits for children who don’t like to take their medicine. With 3D printing, you can create drugs shaped like starfishes or ones that taste like chocolate.
3D drug printing also has the huge potential to change vaccine distribution.
There’s a lot of interest in providing “point-of-care” locations where the vaccines would be printed near where they’re administered.
You’d still have a larger facility making the raw materials, but you could be much more agile and quicker in getting the vaccine to the public. This would be hugely helpful during another pandemic.
Your research focuses on quality control and measurements in 3D drug printing.
Yes, we will need to know that these 3D printers are working correctly. They need to print the correct dosages with the right ingredients. So, we will need onsite methods of taking and validating measurements. This is an area where NIST has a great deal of expertise.
In your journal article, you break down the quality control process step by step. Can you take us through that?
It starts with the delivery of the printing ink to the remote location. You need to confirm it hasn’t degraded, evaporated, or been exposed to unusual temperatures. You want to confirm it’s still good.
We used a technique called ultraviolet-visible (UV-Vis) spectroscopy. There are now relatively inexpensive tabletop and even handheld UV-Vis spectrometers on the market. They work by shining ultraviolet and visible light through your sample. How the sample absorbs them tells you about its chemical composition.
Next, we looked at how you can verify your printer is working correctly. Many commercial printers have LEDs beneath the individual nozzles that print the ink for the drugs. Every time the nozzle releases a drop of ink, it breaks the flow of light, which is detected by a type of light detector known as a photodiode.
The photodiode will detect if the nozzle stops releasing liquid because you’ve run out of ink. If there’s a blockage in the nozzle or even a piece of dust causing irregularities in the flow of ink drops, that will also be detected. In our tests, we found the LEDs and photodiodes performed well.
A future in which drugs are printed on a 3D printer will require the ability to validate measurements on the machine—an area in which NIST has a great deal of expertise. Credit: R. Eskalis/NIST
What about confirming that you’ve printed the correct amount of the drug?
That’s tricky. You need a nondestructive way of confirming the correct dosage. We are working on this right now. It’s the next big step.
What’s the ultimate goal here?
We’d like to produce a series of voluntary protocols or recommendations for quality control and measurement accuracy in 3D drug printing. We will likely work collaboratively with other groups, such as American Society for Testing and Materials or United States Pharmacopeia, to release these.
If 3D drug printing becomes widely adopted, we want to be ready to support both industry and regulatory agencies with a measurement science foundation.
Published June 12, 2024, in NIST’s Taking Measure blog.
next big step ?
1. I'm stunned every day by the creativity of mankind. Haking inkjet printers to help people receiving their drugs ! I would never have thought about that.
2. The "next big step" will not only be the confirmation that the correct amount of drug has been printed. Il will include the competency in analytical measurement of the one using the printers. We know that quality management in medical laboratories is not an easy game to play. What about the analytical skills of a nurse, a medical doctor or a pharmacist ? What about all the necessary burden of metrology, maintenance, traceability - and the associated costs ? And is the regulation ready to accomodate those changes ? I'm not a specialist in CFR requirements or in FDA policies, but here in European Union, such a way of producing drugs would be unlawful (so far).
