Business is changing at a faster rate than ever before, forcing companies to find ways to adapt and pivot. Keeping the entire organization aligned with current goals can be a daunting task, but surviving and thriving depends on it.
One popular method to ensure enterprisewide alignment of assets is to develop objectives and key results (OKR). OKRs are popular enough that industry leaders such as Google and Netflix use them to close the gap between their strategy and execution.
If a company’s OKRs are not well defined and highly visible, front-line workers—and management as well—can often shift energy and resources in a direction misaligned with company goals. And when company goals change, OKRs change to reflect the new direction. When OKRs are front and center, manpower can be spent more efficaciously.
Stretch Goals
Stretch goals. I hate that term. In my experience they're usually set impossibly high by upper management who then does not provide the leadership and resources necessary to achieve them. Later, often at review time, someone has to answer why the goals were not achieved.
I believe Dr. Deming's point #10 had a few things to say about the subject.
Stretch goals vs poor management
